Roon
Aftermarket Radiator.
Roon
Hi guys.
Basically my current set up is dual fan conversion and standard rad. Believe a stock 1.6 gti.
Refreshing my cooling system throughout and just wanted to check if this rad is a direct fit with the dual fan conversion as it is rather tight.
Or any other suggestions many thanks.
121033437754
Paul.
The dual fan, A/C radiator is different to the single fan radiator.
Roon
So the above would not fit my my fan set up?
it'll fit fine, but the listing is not correct, Turbo diesel rads are 50mm thick, the n-a diesel rad is the same as a gti, but not the TD, aircon different again.
The difference is in height, thus you may find it difficult if you're trying to fit an A/C fan setup to a non A/C radiator.
I would not waste your money, a standard replacement rad can be had for around £40 and is perfectly adequate.
Roon
Hmm. This is the thing I don't want to go fitting it it not playing ball and I end up with fitting marks and scratches and unable to send it back.
Is there any other alternative? Standard had crossed my mind but id rather fit and forget and never have to replace it.
And just to clarify I will have a standard gti rad to work in conjunction with dual fans yeah?
I fitted a nissens rad 7 years ago...
Still works fine, still in very good condition.
The rad has no bearing on the number of fans used, personally i'd ditch the second one, there arent many that need two fans, certainly a standard non aircon 1.6 would not need it at all in the uk.
  On 7/31/2013 at 7:23 AM, Roon said:
Hmm. ......
As I said, there is a height difference. Work it out for yourself if you don't believe me. I didn't realise it until a friend bought a std aluminium radiator. We don't have non A/C cars here.
Roon
Ok thanks for the advice guys ill have a tinker this Saturday.
