omri617
Strange Sound When Braking.
omri617
hi..
There is a strange sound when I push the brake , a sound like an old metal wire being stretched ! something I can't really explain ... mm like when you hold a wooden stick and try to break it , the stretching and squeaking sound it makes just before it breaks!!
Checked the brake oil level and it's ok
BlueBolt
Checked the pads?
Coming from front or rear?
omri617
Front , all 4 pads are good have enough 'meat'
It sounds like a rope when stretched !
omri617
How can i know if brake fluid needs to be replaced?
dirtdog
what is it...1.6/1.9? My bendix calipers make a creak like you mention...or as close to it as i can imagine. I think it's bent slides
omri617
1.6 brakes.
PhilNW
Might be the return spring on the brake pedal creaking as it is stretched or the bulkhead where the servo is attached flexing.
There is a strengthening plate that can be fitted, usually to rally versions
Edited by PhilNW
omri617
tried to brake hard last night , and there is a severe turn right when braking , like the right wheel only brakes.
will have to take it to the garage....thanks
DamirGTI
I had one pair of 1.6 front Bendix calipers , and on one side the piston sized up manifest similar braking issues.. in addition the caliper sliders had so much play that i cod hear them knocking when going over a bumps ! was a sound like worn ball joint .
So , 1.6 Bendix caliper are more prone to wear than 1.9 ones .. only benefit - they're lighter than 1.9 calipers .
D
