Ramigojag
Bell Housing And Starter Bolts
Ramigojag
What dimensions are the bolts for these?
I've never worked on a 205 before but got this as a project and all the bolts are in a jumble after the previous owner stripped everything off
It's a '90 1.6 gti
chipstick
Servicebox list them within the diagram next to the part number.
I've sets of them in bags if you'd like to to photograph them to speed up your search?
Ramigojag
I'm on my phone so can't get service box although I didn't think of that so could have done it yesterday.
If you could put pictures up that would be brilliant
starter is three allen socket headed bolts, 10x1.5 60mm long, sometimes you have a 65mm long bolt through the dowelled fixing top front.
the three 16mm headed screws through gearbox into block ate also 10x1.5, 75mm long, and the last lower bolt is a 70mm long 10x1.5 allen headed one through block into gearbox near the speedo drive housing, this one has a square lock washer, the rest have normal round flat washers
servicebox works on mobiles fine :D
Edited by welshpug
Ramigojag
brilliant thanks
i have the three Allen keys for the starter but i think i only have 1 for the bell housing
that's correct, you'll have three 16mm hex screws for the other holes.
Ramigojag
On a side note and separate question I'm fitting the clutch release bearing but when I push the clutch fork to its extent the bearing comes away from the clutch fork
in normal operation would the clutch fork move to that extent?
No, it cannot move that far so no problem.
