Ash13
Help Locating A Coolant Leak
Ash13
My coolant is leaking and i can't see exactly where it's coming from but you guys might know with all your expertise, looking under the car it's dripping onto the drivers side CV boot. The pipe coming from the reservoir into the bottom of the engine seems to be ok but again space is tight and i can't see that well. If anyone could help i'd appreciate it, determined to fix something myself instead of taking it to the garage all the time.
Likely to be one of the following:
  • Leak from the rear coolant distribution block where it attaches to the engine block.
  • Leak from one of the two (or in the case of Mi16's, three) hoses that attaches to that block - the upper heater matrix and the coolant expansion tank.
  • Leak from the waterpump
