Dariooo
How To Replace A Gaiter On Steering Rack Whit Power Steering?
Dariooo
Hi
I have a problem. I don't know how to replace one gaiter on rack with power steering. A problem it's a bolt of cylinder. How can remove this bolt to install a gaiter?
Dario
Duroc
You'll have to take the trackrod off the other end, and take the sprung bush out under the plate (held by 2 bolts) where the pinion is......be careful not to lose any shims that are there). Then you can draw the rack out from the housing.
