309jazzpanda
Base Model Front Subfame Mounts
309jazzpanda
Hi all hopefully I can get across the part I mean
On the front subframe of base model cars, the front of the subframe doesn't bolt straight up to the chassis but has a small rubber mounting, this is the part on my car that is kippeed but it is nfp from the dealers and I a struggling to find an aftermarket part.
Does anyone know of anyone that stocks these things???
farmer
What's the part number may be able to help you locate some.
Mad Professor
I think the OP is taking about Peugeot part number: 3523 33 (FRONT TRIANGLE-ARM WISHBN BUSH).
farmer
Ok, that part is showing as still stocked on service box ?
Edited by farmer
Mad Professor
3523 33 (FRONT TRIANGLE-ARM WISHBN BUSH) - is still showing as being stocked.
3523 39 (FRONT TRIANGLE-ARM WISHBN BUSH) - is showing as NFP.
farmer
The NFP part I can get a pair if that's required?
j_turnell
Is that not referring to a wishbone bush (front triangle arm)? This is what turned up when i first ordered some, the subframe mounts eventually arrived, although this was well over a year ago so they may well be nfp now.
S@m
The correct part is 352333 and it is still available.
352339 is the same thing but for the french rallye - this part is NFP.
309jazzpanda
I have been given a different number but that could be wrong,I unfortunately have left the number in my tool box will get on service box to see if that is what I need
309jazzpanda
just checked my service box and I cant even see the part I am after on it. When I click on suspension there are no documents, the front triangle arm refers to the track control arm from the looks of it
S@m
Its under bodywork and then subframe. Or just type the part number in the search box top right.
309jazzpanda
Yeah sorted thanks guys
