Phil205
Whistling Noise
Phil205
Symptoms :-
“Whistling” noise heard inside car.
“Bunny hops” when first ran, even on warm days.
Poor fuel economy.
Seems to lack power.·
Question :-
Any ides what could be causing the whistling noise ?
I don't think it's the air blower (ventillation).
The whistling started around the same time as the car started to run poorly.
farmer
Sounds like an air leak possibly?
Slo
Check the valve that goes into the brake servo pull it out carefully then run the engine and listen to it it will run like crap while its pulled out though
