calvinhorse
Xu10 Cast Manifolds
calvinhorse
Can anyone confirm the below exhaust manifolds are all the same..
Xu10j4r from 306
Xu10j4r from 406
Xu7 from 306
Xu7 from 406
They look the same but are they internally the same? Stud pattern? Angle of outlet?
Cheers :)
Edited by calvinhorse
all the same yes, just looked on servicebox for you, same part number, 0341A5.
or rather, looking further, specifically the same to 2000 where the part number changed at the same time as some ecu emissions stuff, but appear to be shared across the engines in the same way, later one is 0341 C6, uses the same gasket and fire ring kit,
Edited by welshpug
calvinhorse
Excellent that's good enough for me! Thanks welshpug :)
