justinv
Nothing To Do With 205's (106 Mk2 Diesel )
justinv
Wife 106 has the coolant light and oil light flickering every now and then.
Any ideas ?
Oil pressure switch changed
new oil and filters
alternator works fine
Unplugging the oil pressure switch lights keep flickering
thanks
Justin
minimaniacwhyard
Bad earth? The mk2 ones had a sensor ontop of coolant housing prone to going wrong/ getting stuck. Also check the coolant level if you havnt already
justinv
sorted it was the dodgy connectors they use inline to connect the dash loom to the engine loom
