amusingadam
Sunroof
amusingadam
at around 90 my sunroof is lifting slightly and i have to drop the window slightly to even the pressure is there any way of making it tighter it seals lovely no leaks nothing.Thanks
Simes
My old one did this, never found a permanent solution.
Used to jam paper in between the rubbers and glass.
AndyCrom
Have you looked at the cabin vents to check they are clear, they should let out any excess cabin pressure
johnnyboy666
is this a sliding sunroof or a tilt one?
I've got a tilt one and it appears that the glass is slightly bowed (if that even possible?) in the middle, which causes a leak and a bit of lift at speed, I keep meaning to go on a hunt for one at the scrappy but keep forgetting
amusingadam
cabin vents clear and its a sliding roof
AndyCrom
Is both the lock mech and vac seal working as expected?
farmer
Sounds like a duff seal John?
amusingadam
Everything working as it should, I have taken it to a old school pug mechanic who says its all doing what it should so no idea
