BenV
Door/locking Issues
BenV
Earlier today I went out to the car, put the key in the lock and turned it, nothing happened for a few seconds (ie; longer than normal) then it unlocked, however now the key just turns back and forth.
Luckily its stuck open, rather than being locked out. I've taken the door to bits but I'm not really sure what I'm doing/looking for if I'm honest any help would be appreciated. :) The lock barrel appears not be connected to anything and just rotates.
Is the plastic lever still attached to the end of the lock barrel, and if so, does it move and operate the attached rod when you turn the key?
