ozy
Bushes
ozy
hi thank you for replies re. suspension arm.
i am going to renew the bushes on the gear lever with brass type. I think there are two.
question is do I get to them from the inside of the car or from the underside?
does anyone have any tips or advice on how to renew them ?
thank you.
ozy.
Lan
inside, I think you may have to remove the gearshift dash housing to get to the bolts (can't remeber as my car doesnt have much dash left!) to remove the plate for the gear lever once that is removed you just pull the rubber cover up and your bushes should be right in front of you in the lever
Simes
As above, took me about an hour.
