MiniGibbo
Speedo Not Working..?
MiniGibbo
cable pushed in with rubber pin in place and the white plugged is pushed on..... why isn't it working :(
probably pulled out of the cluster end.
MiniGibbo
I'll have a look thanks didn't think of that
allye
I've had this a couple times, it can push back into the cable quite easily.
jamie_1992
i had this on mine it looks pluged in but its just the outer sleeving thats pluged in the cable inside pushes up inside
i had to get behind the dash and poke it back through
MiniGibbo
Popped off the back of the clusters, thanks guys..!
