fencer
Speaker Spade Replacement
fencer
I've broken one of the spades to with I connect the speaker wire (the one attached on the speaker frame) so I need to replace it. I've found it from the US but I'd prefer if I got it from the UK. Does anyone know who stocks them?
GLPoomobile
Sorry, can't help. But you could just solder a short lenth of speaker wire to the point where the terminal was connected. Put a spade connection on the end of the wire and then you can connect and disconect your speaker wire as per normal.
fencer
That is an option but I'd like to keep that as a last resort.
