rallyeash
Deleting Header Tank?
rallyeash
what rad is that? a 205 with a/c? looks as if it has a header tank..
core sizes as follows...
106 gti 530 x 299 x22
306 gti6 607 x 359 x 32
205 gti 610 x 288 x32
wicked
PEUGEOT : 1300K6 - 1300K8 - 1300X1 - 133035
I don't think its an expansion tank, just a port.
306 core sounds ok, but the tank on the side is quite large, 106 as has been seen will fit, but I'm not sure if a highly modified XU can be cooled sufficiently by the TU5 rad.
205 TD rad is 50mm IIRC.
rallyeash
exactly, the 306 will be generally to big and im concerned tha a 106 rad with a 22mm core won't be enough.
a 106 rad with a 32mm core is what i really want
I know the C2 R2 rally cars use a diesel 106 rad which cools the 180 bhp single throttle body engine efficiently enough for stage use, somewhat harder on cooling systems than circuit I think, but they have a separate header tank !
they are 32mm thick.
Edited by welshpug
rallyeash
Yeah I've been browsing the net and found a 32mm rad, got all excited then realised there is no header tank fitted :-(
found one!! S1 106 1.6 Aircon, Size (H x W x T): 530 x 299 x 32 mm
Nissens No.63521A
http://webshop.nissens.com/Product
(dunno if you can see the pic)
Edited by welshpug
rallyeash
Awesome. Think I'm guna go for that.
Much appreciated!
Spiky
what does your reno 5 rad look like, temped to sell it?
Edited by Spiky
Spiky
just found a pic of it, fancy selly it?
Sandy
I'd much prefer you kept the separate header tank tbh Ash, it's self purging plumbed correctly and most of my serious 106s have been converted to a similar arrangement to make sure no air can build up in the system.
rallyeash
hmm, not sure what to do now!
