lahondal
1.9 And 1.6 Performance Cams
lahondal
Hi all!
Can a Xu9 298º cam, and a Xu5 298º cam have a different powerband?
Can the Xu5 cam be more wilder, although the cams are of the same overlap?
Thanks!
Are they not exactly the same cam so the power band won't be any different?
g
kyepan
are you asking so you can fit one from the other? what's the reason for the question?
manufacturers don't tend to distinguish between the XU5 and XU9 engines, but due to the nature of the engine a 1.6 will rev higher and have a narrower powerband.
lahondal
The problem is that I have a 1.6 engine which should be very revy, but It dont like to rev past 7000. Then, searching the problem I notice that the cam is a 298º degree cam but designed for a 1.9.
Its a Catcams 4900368 and the specs are:
Inlet/Exhaust
-Duration at 0.1mm+cl: 298º/298º
-Duration at 1.0mm+cl: 260º/260
-Max Lift: 12.50mm/12.50mm
The similar 298º cam for a Xu5, have 271º duration at 1.0mm, and a little more lift, 13.00mm.
Thanks for the replies.
Edited by lahondal
its an 8 valve, not many rev past 7k :lol: even a 16v barely makes power past 7k.
its not jap ;)
lahondal
I hoped would be a revy engine, but in the end...
So the best thing I can do is converting it to 1.9? It will not be the revving engine I like but it will make more power...
Thanks all for the replies!!
Edited by lahondal
boldy205
VTEC?
totally depends what you want, you could probably get similar results dropping a 100% standard gti6 lump in there!
shalmaneser
I found my gti6 to be much lazier than my old 8V 1.6. Certainly tons more power but the throttle response is not as good - down to the heavier flywheel i guess.
but certainly much easier than faffing around with cams and tuning the 8V.
amusingadam
just out of interest what the hell did you want it to rev to
omega
and why?
amusingadam
and why?
i was told it was possible to drop the limiter and rev the balls out of a 8v
Edited by amusingadam
to what gain? :lol:
peak is at 6000, limiter at 6200, for a reason, i.e there is no power any further....
granted if you are on a longer duration wilder cam the revs may need to go higher to reach that peak, but you wouldn't be doing that on a standard induction system for sure.
Edited by welshpug
what a random comment, :lol:
the gti6 flywheel is barely heavier if at all, its a square design (86x86) so inherently is quite revvy, I would imagine if you have experienced a tired example in a 300 kilo heavier 306, them that may be the impression gained.
but a healthy example in a 205 it certainly is no contest.
amusingadam
my 1.9 does the job i want it to, it keeps up with my mates jdm dc2 up to around a 100 then i'm out of steam don't think it was made to do that much more.
