johnhenry
Help Identifying This Part
johnhenry
Evening
this picture doesnt show it - but there are 3 wires going into the base of the metal cylinder
Sorting out the electrics in the engine bay this evening - found this; was in terrible condition - is being replaced regardless, just want to know what it is; and what its part number is!
It had 2 wires going into it - 1 brown and 1 purple,
It has C9 stamped on the bottom of it
Roche et Moreau Gennevilliers - Is stamped around circumference on the 'C9' base
It appears to be on its own with no other wires linking up to it in the engine bay, it dissappears off into the interior on the fusebox side of the body.
Good luck!
John
Edited by johnhenry
bondyshambles
Think it may be a fan sensor for the radiator. I dare say i may be corrected.
S@m
It is either the low speed fan resistor or the dim dip resistor. Someone will be along shortly to confirm which no doubt!
Sam
its the dimp dip resistor, sits under the headlamp on the front panel and connects to the lighting loom not engine loom, low fan speed plugs directly into fan loom as pictured above.
johnhenry
perfect! would explain why its so corroded and has a pretty big dent in the side of it; off to peugeot I go! Thanks all
its alloy, probably 25+ years old, its allowed to corrode a little! I wouldn't be worried about a dent, its just a big resistor inside a heatsink, if it works leave it alone.
not sure if you can even get a new one though.
martyn180
What's a dimp dip sensor do? Never heard of it.
Ryan
When you turn the lights on to the first click on the stalk then the resistor reduces the brightness of the headlamps. Then when you turn to the second click the lights get full power.
ade 4wd
As Ryan said above. Its so you dont drive the car on sidelights alone. Dipped beam comes on at a reduced brightness.
martyn180
Would a dodgy one of theis cause my lights to be slow to 'glow? On side lights or would that bean earth issue?
lewis205cti
Dim dip for sure. Yep I'd recommend cleaning your earth connection points.
