MiniGibbo
Alloy And Cast Iron Water Pumps..?
MiniGibbo
Found out earlier they differ... What do I do now..?
I have a alloy engine and piping and trying to fit a bare cast iron block :/
calvinhorse
Use the iron block waterpump and outlet, use the 205 bottom rad - block hose with a bit of trimming down
Easy!
MiniGibbo
I don't have the outlet though :/
Going to have to see if I can find one down the scrap yards..
MiniGibbo
To continue this...
the scrap yard near me only had what looked to be alloy engines, even though the saxo vtr's are cast..??
For those who haven't seen my journal this is my problem..
XSI (missing the bit that goes between the big and little pipe and the block.. and the top engine mount)
Rallye engine (with the all in one water pump housing that I thought id be able to use but cant for obvious reasons)
Now the obvious answer is to buy the missing bits but where..? ebay has nothing and neither does the local scrappy..??
Advice..?
surely the local scrappy has some shonky base model 306's or xsara's in?
MiniGibbo
Going by photos VTR's should have what I need.. They must have all been furious and below I saw.
if a furio has an iron lump that'll do! but I guess it didnt...
early TUD5's have the same bracket btw.
TU3 and TU5 206's have them, as do 306's,
MiniGibbo
You may as well be speaking Spanish to me with those codes I'm affriad :(
A mate told me to look for a iron engine which would only be found in series 1 106's/205's and 1600's.
Guy on moaners might have the bits I need thankfully.. If not a trip back down the scrapyard with a magnet it is..
you best start learning Spanish then lad! :P
do you know S50B30? :lol:
no need for a magnet, iron block is rusty, alloy block is a white powdery thing !
MiniGibbo
I do know the s50b30 :P
Hopefully ill learn the pugs soon as I've got a gti to build :/
Zacky-94
Earlier saxo VTRs defiantly have what you need ive used that exact part off my iron block 1400 onto my vtr block post a picture if you want mate?
want me to grab one at a scrappy if I find one?
MiniGibbo
Thanks guys and thanks for the offer mate.
I'm currently waiting on an inbox message in fb from a dude with exactly what I need hopefully :)
MiniGibbo
Right, I've stuck a wanted advert as the guy on Fb has gone quiet. Thanks guys.
