Zacky-94
Tu3 Head On Tu5 Vtr Bottom End Possible?
Zacky-94
Is it possible to use the tu3 head on the vtr bottom end to retain the orignal carb and dizzie? Cheers
Tandoh
I had this setup with a set of twin 40s. Will all go together fine, but you will have to play around with the mixture adjustment on the carb to get it to run right
Zacky-94
Ive had a fiddle and managed to get the 1400 dizzie to mount the vtr head and it has spark so im gunna mount the carb/carbs to that head i think :)
allye
Stud pattern is different I believe on the inlet.
Zacky-94
I know matey its miles off! i did check haha! , will be making a manifold or having one made havnt decided yet
joed66
Does anybody no the power you get out of these on standard carb and would i use a tu3 head gasket or tu5 also last but not least do the 205 xs gearboxes on the tu3s fit on a tu5
309jazzpanda
Yes the box should bolt straight onto it, so are you using the whole vtr engine or just vhe head?
