MiniGibbo
Removing Throttle Cable, Tb End..?
MiniGibbo
as above any help..?
ORB
What part are you stuck on? It's quite simple.
Remove cable tensioner spring clip thing from outer sleeve to give slack, open throttle manually, pop cable nipple out of the hole thingie. Fin.
Slo
Its no different to a bicycle brake cable
MiniGibbo
Normally you hold the wire and pull the plastic around and it unhooks but I can't see the end..?
Do you push out the little gold coloured peice on the black plastic.?
