JamesE
Mot Advisory...
JamesE
As my car is getting painted I thought I'd start obtaining parts which were highlighted at the last MOT.
One of the things was 'front suspension arm has slight play in a ball joint'
I'm presuming this means a wishbone? If so, am I better off replacing a pair? Look to be about £90 on eBay
Could be the wishbone balljoint is dying, or could be that the hub where the balljoint pin is clamped is loose and/or ovalled.
Some cheap wishbones are pretty lousy quality wise with bushes and - more problemsome as they're not easily replaced - balljoints that last worryingly short amount of time. Historically, Motaquip were the ones to get, but they're no longer made as I understand and recently I've heard of rather too many recent Motaquip 'bones failing in a short space of time as well.
JamesE
Sorry I'm a mechanical numpty - if it's ovaled does that mean a new hub?
Replacement or getting someone like Bridgecraft to machine and repair.
JamesE
Ok cheers, think I better let someone have a look first
starky5
Probably a silly question but is there an easy way to check your hub? Is it just a case of measuring around? I'm about to press some need wheel bearings in so wouldn't mind checking my hub first!
