Zacky-94
Tu3S And Tu3.2 Head Diffrences?
Zacky-94
What's the diffeence between the two heads? Are the cam bearing sizes the same EG. are the cams interchangable?, and anyone know the Compression ratio of the tu3.2 std?
I take it the Uk 205 rallye engine was the 1360 tu3.2 anyway
Zacky-94
Also what are the valve sizes in the tu3.2 ,
Apreciate any help thanks
trogboy
It's been a long time since I owned any TU engined cars but iirc the engine in the UK rallye is a TU3 F.
The cams have the same size journals so is an easy swap. From memory the valve diameters and combustion chambers were the same as the 3S, but I know that the TU3S heads have a "3S" cast in them suggesting a difference.
I'm not sure that that was much use really!
Ad
