Ryan_g1
8V Turbo Conversion. Not Sparking
Ryan_g1
How's it going guys? Having a bit of a problem with my 205. I got the engine in and running about 2 months ago. It was starting no problem. But I have just went to the garage to start working on it and now it isn't sparking. It's getting fuel but no spark. Any help appreciated
Slo
Does the keypad (if you have it) kill fuel and spark or just 1 or the other? sounds a bit unusual for it to not work after 2 months, i had my 605 which my turbo engine came from sit on my drive for about 18 months and it fired up straight away after all that time
Henry Yorke
Process of elimination. Keypad, ignition module, coil pack, HT leads, plugs.
Ryan_g1
I have an immobilised Ecu and an unlocked one. The problem is there with both Ecu's. I don't think the injectors are pulsing as the plugs aren't wet. I've changed the coil pack and its still the same.
Ryan_g1
Well it turned out to be the ignition module. Thanks for your help guys
