stuart
Omex Base Map Recommendations
stuart
I'm almost ready to try to start my Mi16 engine (1.9 ally block), with Gti6 inlet / injectors and wasted spark coil pack.
Just after a bit of advice on a base map to enable me to safely run the engine in and drive to the mappers.
I intend to use a gti6 base map and change the ingition settings for the wasted spark coil pack but will I need to lean off the fuelling at all? If so how much would be a sensible ammount?
Cheers,
Stu
unless you have a wideband just leave it as it is.
stef205
I think I have a base map somewhere, if not ring guy at omex he'll give you one
Not many around for them, the Omex one is a Mi16 map anyway
stuart
If i use the mi16 map won't the fuelling be way off due to me using gti6 injectors?
Yes it will, I'd just trailer it to the RR, better safe than sorry
stef205
As said I have a gti6 map for use with gti6 injectors it was made by guy
stuart
Trailering it to be mapped from the first start up would be the best option I agree but I just need something to get it running at least so I can make sure everything is working properly before taking time off work etc.
I'll see if Omex can sort out a base map for the Gti6 then and see how that goes.
Thanks guys
