mikeygulley
Testing Cooling Fan Switch
I don't know how well that's going to work with the hotter thermostat, as the thermostat opening temperature (88/89 degree) is slightly higher than the switching off temperature for the slow speed on that particular fan switch (switches off at 87 degrees). It might be OK, but equally, it might be that the fan is reluctant to switch off once it comes on.
You might be better with the standard radiator thermoswitch, which is Intermotor 50106 - this switches off at 92 degrees, comfortably above the thermostat opening temperature.
50092: Slow on 92, off 87. Fast on 97, off 92
50106: Slow on 97, off 92. Fast on 101, off 96
starky5
Ok thanks for the info, one final question! Am I right in thinking I can't get a cooler stat? Would be nice to get a slightly cooler stat and use the switch I've just got. If not ill pick up a different switch
you may be able to get one, but it wont be from any std pug that I know of, it'll be a look in the thermostat book and see what will fit job.
or, look on servicebox, google and guess, and hit the jackpot,
1337-53
82 degrees, from a talbot engined 309.
http://www.autopartoo.com/oem/citroenpeugeot/133753n8x.html
looks like its two stage and will fit, used on mk2 escorts!
Edited by welshpug
