Rich
Wing Removal
Rich
Hi everyone, just wondering whats the story with removing the wings from my 1989 205. I removed all the bolts but it seems to be held on with some kind of adhesieve? don't want to go to mad pulling it off.
thanks,
Rich
ok found answer in here.
NFS
what answer did you come up with? share?
Alan_M
Real pain the arse to get off without damaging the wing.
I managed it a few years ago using a heatgun to soften the sealant and a sharp knife to cut through. Painstakingly slow, but take your time and it should come off OK.
I've got a pair on a scrap shell that need removing. This time I'll try cheese wire.
j_turnell
They are a complete arsehole to remove, my preferred method is a heatgun and a very sharp knife, just have to be patient, its a tedious job!
NFS
what about the wire they use to take windscreens out with?
MikeC
If you use a UV lamp, this will allow it to heat the panel without damaging the paint. Will take a good bit of heat to remove it, and some time but worth it.
glenwah
UV or infra red?
bigalthenutter
fast n easy way blow torch and a 1inch blade scraper up the back side of the wing
fu*#s the paint but takes about 10 mins if all bolts are removed
MikeC
A UV heat lamp. Haven't tried it with a IR lamp, but would assume the same effect.
I found the details in the Methods manual for the 205, definitely a help when needed. :)
