pugpete1108
What's This For?
pugpete1108
I removed this from the xu7 head and was just going to block it off .....unless by any chance it's a vacuum take off!!! As I'm in need of one for the brake servo.
F29EAF38-8D0C-4D37-9C65-9485C620A9DB-525
egr afaik.
edit, not quite, a valve to which an air pump is connected, basically a way to cheat the emissions.
SCRAP PILE!
Edited by welshpug
pugpete1108
Right o, in the bin it goes. I'm modding the coil pack bracket to block the hole up.
Where can I get a vacuum take off for the servo bearing in mind I've taken off the nipple on the inlet by the tb for my map sensor.
May have to drill and tap another on the inlet
I'd use the large bore takeoff by the throttle body for the servo, and take the map off the FPR vac feed with a tee piece.
