pier_bruce
Exhaust Manifold Help
pier_bruce
Been looking at customising a exhaust manifold and would like to know if anyone knows the best lengths I should make my primary and secondary tubes?
Any help would be greatly appreciated
Pete
DamirGTI
Help us a little bit :) :
1. Which engine ?
2. Any modifications or just making the manifold for std. engine ?
3. Which type of the manifold 4-2-1 or 4-1 ?
D B)
pier_bruce
Thanks for the reply d
It's the XU9j4 with fast road cams solid followers and a mild tickling with the ports. Bottom end is forged..
On the manifold open to suggestions really 4-2-1.?
Pete
Vili
You'll get close enough by doing 4-2-1 this way:
4-outer diameter 41,5 mm, length minimum 350 mm (I would propaply do 450 mm)
2-outer diameter 48 mm and choose length so that total length is 950 mm
and the actual exhaust diameter could be between 55-63 mm. The 55 mm is better.
Really it all depends what are your camshaft timings and where do you wan't your manifold to work.
pier_bruce
Ideal thanks il see if I can work something out to those dimensions.
