GWtaylor
Washed Engine :(
GWtaylor
Dad washed engine the other day and I started to drive it and noticed it sounded like it wasnt running right with lack of power.
about 1 mile down road and it just cut out still had dash lights but wouldnt fire up
I've put a new dizzy cap and rotor arm on cleaned and dried electrics
it did have a spark from coil but no spark when going into dizzy
is there any fuses or relays I should be checking or and block connectors i could of missed which may need drying
this happenend saturday so it's had a few days to dry out now
any suggestions apart from to keep the father away from the car with a hose
oh it's L reg 1.9 cat
Edited by GWtaylor
yeti-dj
Look for a black box near your battery that has several fuses in it as well as the main battery connections to your altenator and starter. This may be soaked..
good luck
Slo
Check inside the spark plug chambers, I once jetwashed mine and it lost a s*itload of power. Later I discovered the chambers where the spark plugs are had water in them earthing out the spark
ORB
Also ignition amp, dizzy cap, coil connections....
Daviewonder
Make sure the carbon bit hasn't dropped out of the dizzy cap.
2052NV
check all electrical connections for water!!! especially the ignition module and crank angle sensor. also take ht leads off the plugs and blow out all water that will have collected in there. been though this a few times..... the troubles with being fanatical about a clean engine bay :unsure:
chris-gti
if all else fails, i find a liberal coating of WD40 over all the electrical connectors sometimes helps. drives out the moisture
Common for the spark plug holes to fill up with water, whip the plugs out and spin it over, wd40 as mentioned, thats what its for.
GWtaylor
Little update
new dizzy cap rotor arm cleaned leads no spark to the coil now so awaiting a coil in post
lfallgti
Have you looked at the plug thats on the dizzy? It has a yellow plug on a thickish black lead that will stop the spark if not properly connected.
GWtaylor
UPDATE!!!!
It runs
I put a new coil on it and fired up instantly
Now to get driving her again
