Ian205
205 Gti Coilovers?
Ian205
looking for front coilovers for my 205 gti, wondering which would be recomended at a budget of 250-350 preferably . also would be interested if there are any for sale on here
thanks
Batfink
Nothing great at that price. Save up for some Gaz at minimum if you are hard set on coilovers
Ian205
not essential, but i'm getting a 1.9 axle for it so i'm going to concentrate on suspension/braking now for abit , is there anything available at that price?
yes, bilstein or Koni.
don't bother with the 1.9, its the same as your 1.6 axle bar more troublesome brakes, unless of course yours needs a rebuild.
decent pads all round is sufficient for the braking btw.
Ian205
i noticed my left hand leg has abit of play, so yes mine would need a refurb, and the 1.9 was reconditioned 4 years ago and only has 150 miles on it.
ya i'd sayu i'l bleed them and some new fluid,pads and mayble grooved disks
and thanks for coilover info
they wont be "coilovers" they'll be fixed platform standard diameter dampers at that price, height adjustable bilsteins are twice that, for the fronts only.
plain discs is good, you don't need grooved :)
Ian205
would the original 1.9 springs be somewhat lower ? may just get springs for the time being.
i'v a 1.9 bought for parts with some nice mods, may aswell swap the grooved over :)
camgti
Konis or the Billies are a good setup if your looking for something a little stiffer. Ive run them for a few years now and have had no problemson the road. THe standard stuff is pretty good but does not 'feel' that racy if thats what your after.
Coilovers for that money as stated will be rubbish and you dont really need them unless your really hitting the track. They will just be s*it and make the car usless to drive
The 1.9 springs will be pretty similar to the ones you currently have ( 1.6? ). Eibach are a popular lowering spring giving about a 30mm drop, they are also stiffer. You can then have your rear beam matched to amount the front gets lowered by. Avoid getting a stiffer front spring unless your going to fit thicker torsion bars up the rear as it will throw the balance of the car out. Even getting standard springs lowered will be better IMHO. THe rear discs will give you a better pedal feel but many argue they dont do much. You might as well swap the 1.9 front callipers over while your at it. For some reason Ive always found it hard to bleed these cars, its probably my technique or something like a rear flexi pipe has collapsed and given me grief.
I would spend my money on getting the front wishbones bushes and droplinks up to a good standard. When you change over beams I would also fit new rear beam mounts. They are all pretty old now and make a huge difference to the driving experience of these cars. Then you can start throwing stiffer stuff at it!
Have fun
Cam
Ian205
thanks for the info i appreciate it, i will probably just get springs for the time being. they are a bit of a pain to bleed, but it would still be an upgrade in my eyes,
i will be replacing all the bushings and links in due coarse, just want to set it up to my liking first!
allanallen
As cam says I'd go through all the bushes before you even think about 'setting it up to your liking'.
camgti
Definitely do the bushes first. Your wasting you time getting it "how you like" otherwise. 205s are really sensitive to it
Cam
Ian205
on the real axle, just above where the shocks mount. theres a rubber 'block' and when i was taking down the axle half of one stayed in place, there pretty perished . could i get these from a main dealer?
AndyCrom
If your after improving the handling and will be replacing the bushes get some solid ones> http://www.bakerbm.com/205.php?data=suskit205a , granted the cabin noise will be louder but the handling increase is worth it
yes, or a local motorfactor.
its debatable whether solid mounts "improve" the handling.
Ian205
thanks. will probably replace with rubber ones for the moment. whatever i can in the next few days from motorfactor
