dobby909
Satchshift
dobby909
Ok, so ive been looking into these a bit and there clearly the best pieces of kit to get! is there anything on the forum about fitting them e.g a guide? or is it fairly self explanitory once the cars up in the air a little bit?
Ive got a 205 gti with a gti6 engine and box, will i need a different kit? if so which one :)
and another thing does anyone have a good idea of a lightweight flywheel and fast road clutch combo for the gti-6 engine and box, ive posted up on the gti6 forum but ive had no replies -_-
ORB
Flywheel is the same as an MI16 I think.
I'd get a BE3 before doing much else.
Colin Sachell is the man for the shifter. He built it
Could use an XU7 flywheel and 8v 200mm clutch for a lighter option on a budget, will handle the power/torque fine(I run one on a 180bhp 8v), fly has the timing teeth.
rallyeash
Lift up reverse will be an issue if be3/6?
tweeqd automotive
I sent multiple emails to colon about how to overcome this and never recieved an answer
Ive fitted a bmx brake lever to operate the reverse cable in my AX
