omri617
Help Identifying These Things Please
omri617
Hi there
I noticed 2 wires , pulled them and kind of stopped. anyone saw this before?
the second photo , is this tube.
it's not the sunroof drain tube , cause the sunroof tube goes behind the wheel.
Thanks a lot
omri617
Checked the wires , they are connected to the back window washer bottle! :blink:​ :wacko:​ :unsure:​
the pipe is a fuel tank breather.
omri617
I tried to thread a metal cable inside , it's blocked! how can i open it?
Thanks Mei
ORB
Welding wire is the boy for this .
bigalthenutter
if its the pipe to the filler neck is this not an over fill pipe ? with a filter valve type thing tucked up in the arch ?which might explain why it seems blocked
omri617
I didn't understand your post..
cRaig
Basically one of those pipes has a plastic one-way valve fitted. So you might not be able to poke something up the pipe. Perhaps investigate further up the pipe with your eyes to confirm.
omri617
It's pretty dark in there...
bigalthenutter
im pretty certain if you take your wheel off and trace the pipe to its origins, it will go through a hole in the inner arch and up to the filler neck to a valve is what i meant . I have just taken this off mine if you take it of from the valve you can then check if its blocked.
omri617
Tried to blow into it , and nothing. this valve you mentioned , what is it's approximate location? close to the bottom end or close to the filler?
bigalthenutter
if you take your wheel off on the side the pipe is showing you will see it goes up the inner arch, up to the filler neck on the inside of the wheel arch. il try grab a pick of mine and post it up
omri617
