ORB
Plip Keys
ORB
Just robbed this from a 405 we have in stock along with the guts from two keys.
F0F0A654-1028-46EA-B915-C144E2120207-434
A94BB9DB-316C-4B29-AA71-B481D7EC65D4-434
Will this plug into my phase two 205 ok??
ie: direct replacement
Yes, it's a straight swap - it's what I'm using in my own 205 :)
You have a complete 405 there?
ORB
Yup, but it's to be traded, it owes stupid money!
1.9 quasar with 79k on an N
Blue 4 saloon
ORB
Yup, it works.
Just a bit of a faff getting the inop key working then swapping the blade over (a bit of filing and drilling)
Nice genuine looking remote key for my car!
Exactly as I did with mine:
It's a nice modern OE-looking touch :)
damn you phase 2 ists!
chipstick
How much work is involved in fitting one of those receivers to an older vehicle? Say if you were to get one with the cable.
It's not that difficult, but is more involved than you first think - as well as the lack of wiring for the receiver, the drivers door locking motor is different, as is the wiring, and there's a control box under the dash as well that isn't there on earlier cars (nor is the wiring). Basically, it's a dash out job and swapping over a fair chunk of the central locking related wiring from a suitable donor.
Probably easier to just buy an aftermarket RCL kit (or a suitable alarm with RCL built in) if you're not too fussed about having an OE kit - to be honest they'll work better too, as the OE setup isn't brilliant being IR based rather than RF (as found on later 306's etc) which typically has better range and doesn't need line of sight.
chipstick
I did pull out that black rectangle control box and a fair chunk of wiring from a ph2 for Justin Case, but as you say - for that work involved it probably is worth having a security system fitted that does it all at once.
ORB
Here's how the keys are done.
Take both keys, mark scrap blade with tippex
8CE73C83-E316-42D9-850B-94F694CDAB63-306
Undo screw, open up case and pull blade out.
86671F1E-3012-41DD-BD70-221EFF2392B8-306
Take original key , cut it up to remove the blade. Stanley knife works well cutting along the lines in the key plastic
6164DD39-2556-42A9-8402-E7D4B8A107BB-306
Blade out
FD161D36-66C8-416F-9181-C6759FFAADAB-306
Put old blade ontop of one to be modified to fit plip, mark up excess and hole to drill.
897727A7-4ED8-4F51-89D7-FF99225E02DC-306
Now cut and file off waste and shape to fit original size.
AB51A87D-506A-4226-B0F5-179FABB7E6E2-328
Bang it all back together and away you go!
FC945EA3-E8C4-4ABD-B06E-189FFACBA11B-306
Weser
Nice thanks for showing that - very useful. After seeing this post I went on ebay and emailed a guy who is breaking a 405 and have a receiver and fob on its way to me lovely job. So this will be very helpful.
Josh_Quant
or just a new key and get it cut :P
ORB
That ruins the fun!
