GWtaylor
My 1.9 Miami Blue Tidy Up
GWtaylor
Just bought her yesterday with a 500 mile round robin
all the pictures i have for now
Will get more tomorrow if it's not raining and a list of stuff I can see needs attention
This will be my daily driver and it's just got a years MOT put on it.
Would love to do a meet up in the future of other fellow puggers
GWtaylor
Little problems i found out tonight with bulbs out
Before starting
I know normal beam bulb is out high beam works though
Should i see the low water light?
0B7FE021-989C-455D-9632-5412EABFF09D-236
Oh oil temp guage not working either
Does this look alittle low for cold?
4BAE7CF1-452D-4865-ADC6-0D2CA2517657-236
Good stuff, ignore the oil pressure as many a time you can use different senders and dials and get all sorts of readings, Mind you should have a engine Diag light on too (Top right) as it's a CAT model
GWtaylor
Thanks miles
I'm off to work now for a week so when I get back I'll check all the bulbs
Is there any LED upgrade bulbs you can get for these or just brighter ones?
Also anybody got a picture of how many lights should be on on the 1.9 cat model
GWtaylor
Some from half an hour ago
Faded roof but used this as a bargining chip
Yep the dreaded rust
What can I do to temp fix?
I was thinking of grinding back apply "Kurust" then prime
johniban
geet a wire wheel on a drill or on an angle grinder clean it up to bare metal, apply etch primer to the bare metal then 2k primer and 2k paint :) the miami blue in a can is pants
You're also missing the alternator/charge warning lamp. You need to sort that one, as without it, the alternator won't charge with the engine running (at least until you're doing sufficient rpm for the alternator to self-excite and begin charging).
Low coolant warning light will not light on ignition on, unless of course the coolant level is low (assuming the sender actually works, which many/most don't!)
GWtaylor
Thanks jon
Will try this the weekend if funds allow as paid day aint until the week after lol
johniban
i know how you feel mate my 205 is currently rotting away in the garage as i cant afford to do anything on it. mine is similar to yours i have a miami blue that came with grey carpets, but my dad wanted red carpet when it was his
j_turnell
Looks like from the picture the alternator belt has seen better days! Surface rust looks minor though, but best to sort it now before it gets any worse.
GWtaylor
Yea it is naff
it's geting a full service soon belts, plugs, oils ect
MiniGibbo
Miami just looks epic..!
GWtaylor
acouple of pictures from today
ok that didnt upload will try again
GWtaylor
Well not really much of an update but
fitted front flat blade wipers
also fitted xsara front wiper jets but they dont spray far enough up the window and they seem to be non adjustable unless somebody knows something i dont on how to adjust them
BAD points
rad expansion tank has been leaking at some point and fixed with rubber sealant
I'd get pics up but the camera is nikon and all files are NEF files and dont know how to convert them to jpeg so i can upload them
GWtaylor
few pictures after washing
No pictures of the new parts fitted yet
Projectuno
Is it just me or do the later 1.9 cars sit higher at the back? 1993 cars.
GWtaylor
Don't know actually but I know i get a bang from the rear everytime i hit a pothole or small bump in the road still investigating what it could be.
sounds as if it's coming from rear drivers side
DanteICE
Would it be possible to buff/polish that roof back to life?
GWtaylor
I don't think so as a painter said it's the lacoure which has come off like
also got all my dash lights working the otherday still no pictures until the weekend now as away again :(
I might try to polish it out but hand polishing wont do it may have to get a maching polisher
scottbarton
This could be the rear bump stop that has made a bid for freedom. Mine did the same. Easy enough to replace. Pug call them rebound blocks.
http://forum.205gtidrivers.com/index.php?showtopic=147589
Also get some Plasticare on those bumpers...it will bring them back like new!
Here are some pics of my Miami Blue after i treated the bumpers and replaced all the trim.
http://forum.205gtidrivers.com/index.php?showtopic=149171&do=findComment&comment=1344062
GWtaylor
Yours look excelent
funny you should say that as I've just ordered a bottle
GWtaylor
UPDATE
Car now runs as fitted anew coil and it fired up straight away all bulbs working on dash so just going to get a few miles under the belt like
mechanicalrepairs
Scared me a little, nearly the same reg as mine.
Carl
GWtaylor
Lol get a few pictures of yours up
