bigalthenutter
3 Door Water Seals
bigalthenutter
hi people any one know where to get the stick on water seals for a three door ?
nickaliath
Peugeot dont do them anymore, I had to carefully remove and restick mine when it got sprayed. Not ideal but no choice.
bigalthenutter
i have some already i was after new ones really what do people use to stick these ive tried allsorts but they keep peeling away
Dukey
Ooh, this might be what I need, never seen em before. Do these go on top of the door? There's always a drip when I'm driving.
bigalthenutter
yes you have your seal which goes all the way round the door. then there are these which go at the top of the door shut on the outside of the seal .
if you are missing these water will piss in all the time as these have a channel which takes the water away from the top edge of the door
Dukey
Ah cheers yeah water does piss in, wet knee every time ha. chipstick is going to sort me out with a pair.
