Karl
Knocking Sound On Right Hand Cornering
Karl
hi everytime i go round a right hand bend im getting a knocking sound not sure what it is its only R/H and not left any ideas??
cheers, Karl
Slo
More than likely your offside cv joints/driveshaft
dcc
Ill go with f***eded.
Karl
ok thanks lads ill get a new drive shaft asap is it a immediate attention thing or will it be ok for a bit
A failed outer CV will knock relative to roadspeed (ie it will knock faster the quicker you're going) and will typically be only present (or atleast considerably worse) under power.
Slo
It could last months or collapse in 5 minutes but nurse the throttle especially when turning no hard accelerating it will probably see you through till you can swap it
Karl
thanks anthony that is exactly whats happening will have a look will it need replacing asap ?? or will it last ive had them shaft fitted only about a year <_<
great thanks mate
Not entirely surprising it's failed in just a year, as many "new" or "recon" shafts are utter garbage these days sadly :(
Karl
anyone know of anywhere i can get decent ones from??
Edited by Karl
