lee.kendallmi16
Gti6 Inlet Manifold Onto Mi16 Engine
lee.kendallmi16
Will the Gti6 inlet manifold fit the mi16 head? Also would that mean I use a Gti6 throttle body with it and be able to keep the existing mi16 AFM??
Problem I've got is a standard mi16 throttle body with a vacuum leak,
Simes
I ran a Gti-6 inlet on my mi16 but binned the loom and everything else inc. Afm, dizzy, ignition amp in fact all the old engine side of the loom.
The car ran on an emerald ECU and loom, coil pack from a 106 and made use of the tps, air temp sens on the Gti-6 inlet.
It made 10 more bhp.
There are pictures and write up in my rebuild thread in the project section.
lee.kendallmi16
Thanks for the response guys!
I will take a closer look at this now I know what's involved.
The hardest part of the job is doing a neat job with the oil filler/breather pipes. Something which the linked thread above didn't address.
luggy
I used 8v filler pipe and located it by the alternator so the inlet by the throttle body area isnt quite as cluttered.
Found that the pickup at lower rpm did improve a little.
Edited by luggy
dcc
You could fit an Audi throttle body.
lee.kendallmi16
The VAG/Audi 2.8 v6 throttle body looks like there's less work involved and less parts to source.
Has anyone else had the experience of fitting this throttle body or owning an mi16 with one fitted?
Craig.Mi16
im also quite curious to know, would there be any benefits from a larger choke area?
Simes
This was tried out by an old forum member "Dino" on his 205. Can't remember if it was on his 8v or 16v - or in fact if there were any gains. Would have been around 2003?
google 205GTI+throttle response!
lee.kendallmi16
From looking into this, I've found that only the VW 1.8 16v PL engine throttle body can be fitted and not the one from the KR engine.
Can anyone confirm that it is only the audi 2.8 v6 throttle body that can be fitted and not the 2.6 v6 (I think 12v) throttle body. Or can both be used?
There are loads of 2.6 v6 available on flea bay with a TPS fitted and it looks the same.
S@m
Seems like alot of VAG cars use that same throttle body - some people say 1.8's, some say 2.9's. In fact i have a 80's scirocco gtx TB here in front of me that looks the same except it has two TPS switches as opposed to one - one for closed throttle and one for wide open. I know i haven't been much help but what i am trying to say is that you may have to suck it and see - either way you will have to modify an mi16 TPS to fit.
I looked into doing this mod a couple of years back and have since decided to just go to the extra effort of fitting a gti6 inlet.
Craig.Mi16
can you run a gti-6 inlet and throttle body if you have 8v management with dizzy adapter etc?
probably, but if youre going to the effort of making the inlet fit you might as well do a proper job and find the proper management.
I have seen a 2.2 Audi TB that looks the same.
Edited by welshpug
Alan_M
I don't think it's been done before. Don't see why it wouldn't work* seeing as all you're changing is the TB essentially. The 8v TPS is the same as the Mi, but you'd have to get ingenious with the piping for the SAD and all the breathers. There's no right way of doing this, and it's pretty much ad-hoc.
If it were me, I'd be finding Mi management and getting that sorted first.
*Doesn't mean it'll work well though!
Craig.Mi16
ok ill try source a 16v setup or like simes suggested and save up the pennies, ditch the whole lot and go for a 3rd party ecu and loom.
Simes
Yep it will save you time in the long run
This was my old set up
Craig.Mi16
looks awsome mate, much more tidy than mine ive got hoses everywere haha, ive read that its quite straight forward here or so it seems http://forum.205gtidrivers.com/index.php?showtopic=131742 is that pretty much it? i see you dont have the mi16 afm though do you not need it with aftermarket ecu set up?
Simes
That's right, tps etc is all built into the throttle body. Much tidier.
S@m
Simes, just out of interest, does your management also use the gti6 MAP sensor in the inlet manifold or is it only the TPS? Since i hope to use a similar setup down the line.
Sam
Simes
I don't have this set up anymore but all it used was TPS and Air temp, no MAP as far as I can remember.
When I fitted the throttle bodies on the electrical sie I simply unplugged the TPS and ATS from the GTI-6 inlet and plugged them into the new components, I drove it to Emerald on the same map, a bit lumpy but I knew it wasn't going to do any damage.
