ORB
Oil Adaptor Problem.
ORB
I have one of the oil pressure adaptors where the sender screws into the side and the switch screws into the end.
What is the correct way to install? I have tried twice and can't stop it leaking (badly)
I can't quite see where exactly it's coming from but it's deffo the adaptor.
Any advise?
Parallel threads seal on the "face" and so need a copper or dowty washer. Tapered threads seal on the thread and need thread tape (PTFE).
ORB
So, I understand what you are saying.
I have 3 washers on the end of the adaptor, and some RTV for good measure. I have a fibre washer or two on the pressure sender and a copper washer on the switch on the end (this appears to be good)
What's next? (Other than strip out the radiator AGAIN to sort it...)
pugpete1108
I found plenty if ptfe did the trick on mine and a copper washer on both end connections.
ORB
I'm in the garage as we speak seeing if I have PTFE still.
I do.
Sort that again tonight!
j_turnell
I've always used pipe seal made by wurth great stuff.
deathbringer929
i just used ptfe tape on mine been fine for over a year with no copper washers. just do what it stands for and Put The F***** Everywhere, any pumber would tell you that. :D
stu8v
Except when it goes floating around your engine and then "kills" it.......
Its the devil, much like excessive silicone and RTV.....
ORB
Well, a small amount of PTFE and we are no longer leaking.
TA!
