stef205
Gti6 Phase 1 Cam Pulleys
stef205
I'm looking to adjust my cam timing, as was thinking about using the phase 1 cam pulleys does anyone have any experience with theses. I'm only thinking of changing for easiness. I've heard that some have failed. Any input would be great.
Do you have the later single bolt type on there are the moment? you can still alter the timing with these as well.
stef205
Yes I have the later single bolt, I'm aware they can be adjusted, I was looking to use the earlier ones for easier adjustment.
Paul_13
I wouldn't say they are easier to adjust at all.
If you use them be careful when tightening the bolts as I'vebroken one across all 3 bolt holes
The 3 bolt type I do find easier over the later one's, But as said do not do the bolts up to tight or check for them being over tightened in the past,
They work well if looked after, the set I have have cover 280k without any issue's and no one can beat that
stef205
I had the similar type on my saxo vts, I take it the phase 1 pulley will bolt straight onto any phase cams?
yes, though you will need to trim the ribs on the inside of the later belt cover to clear the bolts.
Edited by welshpug
