kyepan
Brand New Starters - Where From? What Make?
kyepan
Hi there,
My new (less than a year old) starter appears to have lunched itself, after my girlfriend tried to start the car against a kerb in gear.
It sounds like the bearings have let go, in addition to having trouble withdrawing the solonoid, so all in all, a bit broken.
Where should i get a new (not reconditioned one ) from, XU.
J
brumster
Didn't realise you can still get new ones - Pug directly maybe?
Why not recon (I mean, recon is as good as new in all the main concerns - motor windings, bearings, bushes - who gives a toss about the casting and casing, even though every one I've bought has always looked as good as new anyway!)?
servicebox lists "new" at £280, could be bosch ducellier or valeo, or an exchange item at £113, both have a surcharge but I dont think this is much, something I have heard also is that the exchange items are new units as not many, if any at all get sent back for remanufacturing.
If its less than a year old & was brand new when fitted, isn't it covered under the 12 month manufacturers warranty?
g
kyepan
g
probably, but i'm a bit slap dash at keeping receipts.. tbh i can't remember where i got it from!
So bosch or valeo then... ECP ok for this?
should i be aiming for a 306 xsi starter, or other?
thanks guys
Edited by kyepan
Richie-Van-GTi
XUD starter, get a valeo unit and it will probably see out the cars final years.
kyepan
You'd say that,but I had one and it failed in a few months, think I've been through 4 starters...
jord294
personally, if you can get hold of a 306 gti6 starter, then get one of them fitted.
a lot slimmer to fit aswell
