James_K
Gti6 Diagnostic Results - Advice Needed
James_K
Several months ago, my 205 gti6 developed an annoying hesitation/misfire above 5,000rpm (accompanied by K-light flashing) and its got progressively worse – apparent at lower revs now also.
I’ve been around the houses replacing things like plugs, coils and various sensors, with no effect. So I finally got a diagnostic port wired into the loom and got it hooked up to Peugeot planet to try and get to the bottom of it.
First thing I noticed was there were no faults registered if the car was ticking over or even revving gently. However, if it is taken up to around 4-5k revs it starts throwing out faults. First time I tested it gave the following:
Permanent fault – steering sensor (no PAS so to be expected?)
Intermittent fault – Vehicle speed sensor function
Intermittent fault – Coil 1 control function. Open circuit or short circuit to earth
Intermittent fault – battery voltage
Intermittent fault – Coil 3 control function. Open circuit or short circuit to earth
Intermittent fault – Coil 4 control function. Open circuit or short circuit to earth
Intermittent fault – No. 3 injector control function. Open or short circuit to earth
Second time (next day) I had the following results (again no issues at idle, faults only generated when revved)
Intermittent fault – idle regulation stepper motor control function. Open circuit (this is correct as it can idle badly on start up)
Peugeot planet says to check the loom, connectors etc. for each of these issues. My auto electrical knowledge isn’t great, could it be as simple as a bad connection/earth somewhere on the loom?
I find it a bit odd that the errors aren’t consistent and they only appear when the car is revved. Could there be something else causing this? The conversion was professionally and tidily done in the last 12 months (not by me).
I was thinking of getting an auto electrician to check all the connectors and loom etc.
Any idea what I should do next or had a similar experience?
thanks
jamie_1992
what senors did you replace as that seems to be showing the crank sensor and the coil packs
cheak all your earths are good and clean
maybe the plugs on then coil packs are loose or slightly damaged which is why it only happens when reving and the engine i vibrating more? only a guess tho
James_K
I changed the crank and cam sensor. I will check the coils, but they're brand new. I think it's more related with the increased electrical load at higher revs, if that makes any sense..
Richie-Van-GTi
I would definatley be looking at earth points before anything else. That or the regulator in the alternator is acting up. Have you tried revving it with no alternator belt on but a fully charged battery.
James_K
Hadn't thought of the alternator being the issue. I'll check the earths then try taking the belt off.
cheers
Emmy Seize
"Intermittent fault – battery voltage"
As Richie suggested......
My mum's 206 cc showed similar faults shortly before the alternator gave up completely.
James_K
Richie & Emmy, I think you may be right with the alternator being the problem.
I removed the belt and it revved more cleanly, without any of the coil pack faults showing. I'm still getting warnings on the injectors though - not sure whether this is due to poor voltage from the battery as its only generating 11v without the alternator.
I've got a new alternator on the way, hopefully that will cure it.
thanks for your help
James_K
Thought I'd finish this post off in case anyone has the same issue again, I changed the alternator this morning and the car now runs absolutely perfectly again. I'd never have thought that it could cause hesitation and all the other faults, but it's now pulling like a train again.
thanks
camgti
Awesome News. I have a 6 with a hesitation here and there and thought it may be that too. Ill investigate further. Thanks for finishing off the post
Cam
