Moz_Goodwood
Plugs Behind The Clocks
Moz_Goodwood
Hi I'm starting to put my car back together, I inherited it in bits so I'm a little lost on some things. One of which is putting the clocks and surround back in, but I seem to have alot of plugs and nowhere to fit them!
There is one that goes into the dials ~ circled in blue
Two for the front and rear fog lights ~ circled in red
That is all I have to plug into the clocks and their surround, so what are the green, grey, black, pink and yellow ones for?
If it makes any difference it's a phase 2 309 Goodwood GTi
Cheers,
Paul
Edited by Moz_Goodwood
Pink looks like the dimmer
Blue is tacho
Black, green, grey and yellow circled ones are for the instrument lights and gauges
Moz_Goodwood
Now that's what I thought, but there's only a couple of places they can be plugged into. Do I have the wrong clocks for the car?
Back of the clocks (only one socket which is the blue circled plug)
Back of the surround (these are the two lots of foglights the red circled plugs)
They only fit one slot anyway, I can't see anything wrong there, 5 slots 6 plugs, the brown plug with two wires is for the instrument lighting dimmer which is on the steering column covers.
The fog switches are colour coded and keyed so you can't get those wrong.
Moz_Goodwood
8 plugs and only three holes
See the four connector strips along the top of the instrument panel - that's where the four larger connector plugs go for the gauges/lights....
Moz_Goodwood
ahhhh got you didn't realise they were connector strips :blush:
Think I had a "couldn't see the wood for the trees moment" :lol: cheers all
Moz_Goodwood
All in now cheers, was so obvious in the end :blush:
S@m
Been there and was equally confused since someone else took it apart, they are staring you in the face when you realise.
Edited by Sam306
