GWtaylor
My Grey 1.9 General Overhaul
GWtaylor
Just bought this
G reg 1.9
Full service history
Recent engine rebuild
Upgrades as far as i can tell so far
Lowered with koni shocks and springs on the front
Lowered rear with koni dampers
New bottom arms
2 brand new wing mirrors still boxed
Original radio
Interior in good condition
Rear stainless back box
Bad points so far
Needs new drivers side full sill
Drivers door dropped
Passanger door dont open
No mot or tax
Each door on its own lock and key
Bonnet paint cracked and has horrible bonnet pins in
Well here she is
1FB8AB6F-6E8F-4350-BA68-D32D508E3CC5-397
473E617D-EA78-4F92-92E7-FC1300F3493C-397
3A08C99D-D330-4534-9814-27A3D1D7CAF5-397
4AC620A0-CDBD-4FBA-9D75-1E19DB617D2C-397
4D9DDF19-75B0-4861-9277-C7EB43B3EC28-397
58F3BA26-1089-4498-A548-907907BE87A6-397
BE25F492-E73C-4071-8C8C-49B8B7A716F1-397
GWtaylor
All comments welcome positive or negative
sort them brake hoses!
GWtaylor
Yea will be found a full set of brand new braded hoses in the boot so they'll be going on
GWtaylor
Managed to get under rear this morning
HORRIBLE
will be stripping it back to get some hammerrite smooth black on it
More horrible yellow
Horrible bonnet with pins
This is going in the bin
Some sort of saxo rear wiper arm
2 bloody ariela
GWtaylor
Seems to have had welding done luckly it doesnt look like hedge damage
JakeMathias
not a bad base car for a project ! what was going through somebody's mind though when they decided to paint the rear beam yellow ?! Are you planning to do any modifications to it or just restoring it ?
GWtaylor
Restore it and x2 what could possibly of being going threw is head. Everybody to there own just not to my taste so i'm eventually going to strip it off and paint it black
GWtaylor
Looks like another one for the scrap yard in the sky :(
As i cant weld and imagine this is going to cost a fortune
5A1D402B-F3A7-4C59-832C-E5FF07A9573A-125
4C1043B1-13C4-4528-84F9-848DE022FA83-125
Inner sill
89BF009C-633C-4144-AA56-ADAFE417FB9E-125
F07BFCDD-6C32-4EEC-89AA-2885286102F8-125
A07BDEDD-1A9D-4FEE-9039-0CA11DB79761-125
Its quite extensive but certainly not the wost I have seen and wont be hard for a decent fabricator to fix up, certainly not something I would scrap it for.
Puzzled why you bought a car that you knew needed welding and a replacement sill if you weren't in a position to do it yourself nor were willing to pay someone else to do the work? :unsure:
Whilst sills in that state are still comparitively rare, it's certainly not unheard of, and all 205's are getting to the age now where tin worm is beginning to take its toll and repairs are going to be needed. Front inner wing seams, lower rear quarter panels, rear bumper mounts, headlight panels, above/around the fuel tank, and the boot floor are all becoming very common areas.
Have a look at M@tt's CTi project thread as he's repaired/replaced a sill in much the same condition, and doesn't look to be difficult for someone experienced. Certainly similar repairs are going to be very common on other cars from that era, just a question of whether replacement sill panels are easily available to make the job comparitively easy.
JakeMathias
Defernatly not worth scrapping..
GWtaylor
When i bought the car i thought it was just bottom half of outer sill and my sad was going to weld bottom half but he's only good at simple welding so on discovering more he said it's too much for him to handle.
I've already go replacement outer sill its the inner sill which i can't get hold off
I've got a bloke coming round tomorrow to give me a quote so fingures crossed then it will be in my budget then it wont have to goto the scrap heap
GWtaylor
On another note
This is the crappy induction kit on it so what can i do with these 2 pipes may be get a oil cath tank for them to go to?
F1E36723-01C6-458A-BC84-FA1F8A1EC731-125
29DF58A7-281F-4B7C-A05C-10A6E403E8F4-125
you need a K&N induction hose, it will have the two takeoffs you require, did you not place a wanted ad for one of these recently?
one pipe is a breather the other is a feed for the SAD which should be connected engine side of the AFM, not to atmosphere which will in effect introduce unmetred air into the engine causing issues.
GWtaylor
WELSHPUG
thanks for that and yea i ordered a k&n arrived yesterday
Judt fitted it and plumbed in the sad pipe an presto my car now idles perfectly
GWtaylor
Now for the next wiring and odd plugs
D630CC2D-BF11-4F9B-9FAC-9C4D584E124D-125
A5469576-0FA9-4E84-948F-18C5D39C4BD0-125
That was back of block
GWtaylor
Ohh and YET another biggy
My passanger door wont open
From either inside or out i've got door card off looking in but everything seem to move freely
GWtaylor
UPDATE!!
First real day around the car as per some of the pictures above
so stuff I found so far
Faults
Front right indicator not working
rear left indicator not working
rear fog light not working
Passanger door won't open
Ideling issues
blown centre section of exhaust
bonnet hinge bolt snapped
Drivers door sagged
