Smithster92
1.1 Drive Shafts To Gti Hubs
Smithster92
Not sure if this is the right place or not but i have a 1.1 205 96 (P) and i was after a set of gti shocks and hubs with breaks will this be a straight fit? Cheers james
1.6 gti will fit, 1.9 will not.
Smithster92
How can i tell the difference pal? Cheers
ORB
1.9 shafts have a hole drilled in them at the wheel end to accept an R clip and 1.6's have a nut with an edge to peen down to grip the shaft.
Smithster92
Cheers guys
Not quite that simple, i have 1.9 shaft with the staked nut.
Base model and 1.6 use m20 thread, 30mm nut, 1.9 uses m24 threads and 35mm nut.
Smithster92
Will the bottom ball joint still fit or will i need a new subframe/bottom arms? Cheers
that is the same size
Smithster92
Thankyou guys
calvinhorse
You can keep your original hubs and fit 1.9 brakes and gti shocks
It is now, it's brakes btw.
Struts for either a 1.6 or 1.9 will fit straight over but the antiroll bar drop link attachment can hit the inner wing rigid brake pipe to flexi bracket & the springs might not be best suited to your car due to the engine weight difference.
g
