norm
Cannot Open Boot
norm
hi gang ,come to get into the boot but no joy can open drivers door and passengers doors, but no joy with the old boot? any answers
could it be the central locking ? if so how to rectify the prob
cheers norm
ORB
Have you tried the key?
norm
the problem i have is that when i bought the car i got two keys both will not open the boot but the central locking always opened and locked it ?
pugpete1108
Iirc you can access the boot lock from the inside to open it then investigate further.
The boot panel is only clipped on and can be removed with the boot shut?
norm
cheers for that !! i'm on for that now, but after further investigation i cannot hear the remote lock working, i.e making any noises, once I've got the boot open where is the remote motor?
pugpete1108
It will be attached to the lock by a rod.
It's located next to the lock mech
norm
is there also one for the drivers door?
norm
i have a manual for the car,but like most things, it goes missing when you want it!!!
bondyshambles
The drivers side one controls the boot and the passenger one too. I had a problem similar to this and i had to change the main actuator in the drivers door to sort it.
norm
can i repair? or is it a replace
Daviewonder
Take it out and have a look, could be something as simple as dirty connections.
norm
cheers will do, if i have to replace how much ££££££££££££££££
Daviewonder
Second hand under a tenner.
norm
thanks for that
norm
thanks guys took the drivers side lock and central locking out and gave it a good clean and oiling ,works fine now
cheers
