mmcgtk
206 Rack Into 205
mmcgtk
ive a 206 and a 306 power steering rack in the garage,would either fit the 205 with some mild modification?
S@m
The 306 rack is a straight fit as long as you swap the tie rods and track rods for 205 ones.
I don't know much about 206's but i doubt that one would fit without some effort.
Sam
It wont be a direct fit as the mounting studs are vertical not horizontal, though I doubt it'll be beyond the means of a decent DIY fabricator to make it fit, I bet the track rods wont even need changing as the 206 isn't that much different in track width.
they share the same cranked male track rod end as the 106/307/605, which is the same thread as a 205/306 and many more.
As Sam mentioned the main body of the 205 309 306 zx xsara berlingo and partner rack is the same so they'll all bolt straight on, just need 205/309 track rods and a suitable lower steering column from a later 205.
