bigalthenutter
Rear Drum Advise
bigalthenutter
are there any diferences between standard 1.1 rear drums and gti drums ?
Daviewonder
I believe the GTI had wider drums.
Yes the GTi's use the widest drum, Base models are thinner
The rear wheel cylinder is also different, base models have a built in compensator & larger thread union into the cylinder.
g
bigalthenutter
thanks folks iv got issues of tyres tearin out the edge of my quarter panel on my 1100 shell .im running 15 inch speedlines but i think its down to the offset on the hub .
probably because there gti hubs then. i want to increase the width of the rear track and tuck the wheel in with a bit of camber is there any easy way of doing this ?
dcc
Easy... No. Possible... Yes.
I forget the manufacturer, but you can buy a 'wedge' that alters the toe in and camber of the hub on the trailing arm.
bigalthenutter
great thanks il research this :)
