Powers
Bilstein Tarmac Inserts Re. Long Spindle
Powers
I am replacing some inserts as they are short spindle for some long spindle ones from my spares
However the spindle length seems really long. It measures 58mm. The short ones were 26mm.
Long spindle inserts:
Part number 59472 375 225
Total length 574mm
Body Length 320mm
Short spindle inserts:2906V36 0548HO
Total length 542mm
Body Length 390mm
Are these the correct long spindle inserts? I can sort of remember getting them off a Works 306.
rallysteve
Yeah that is the same length as the long spindle inserts I have. I have got a set of the PTS top spring caps which have quite a thick spacer section on the top, presumably to take up some of the spindle length.
Steve
