niklas
Electronic Speedo Sensor
niklas
Have anyone used a electronic speedo sensor with an aftermarket ECU?
http://www.ebay.co.uk/itm/PEUGEOT-206CC-2001-2-0-16V-GEARBOX-SPEED-SENSOR-2576063A-/271094658511?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1e8035cf
Would be interested to know the pinout of that kind of sensor.
I guess I'll feed it with +5 and GND from the ECU and get a signal of some kind out of it. Perhaps something similar to the trigger signal?
[L'e$kro]
It's a hall effect sensor, it outputs a square wave signal. It's like the cam sensor signal, not the crank speed sensor one.
For the pinout, you have it in Autodata, or in the Haynes manual on MP3.2 and 1AP available in that forum
EDIT: Here
Nico
Edited by [L'e$kro]
niklas
Wow, thank you very much!! Much appreciated :D
o.e ecu's use that sensor at 12v.
stef205
i used one of those on my omex and it took the earthing side out on the ecu! had to have it repaired
