FireFly
Xantia Manifold Clearance On Xud9Te 205
FireFly
I've seen Max/Strictly has used an adapter for the standard inlet manifold but I've yet to see someone use the Xantia/406 manifolds.
Is this because they don't fit?
If theres space for the TMIC I'd guess theres space for the Xantia inlet.
Can anyone confirm this?
deathbringer929
yup, bonnet closes fine with 406 inlet plenum. im halfway through fitting fmic and this was checked first. little bit tight for getting air inlet into turbo though.... :unsure:
FireFly
Hmm interesting, thanks for confirming!
